R/C Transmitter and Receiver
Radio control systems can be expensive and confusing with their various incompatible protocols (FHSS, DSSS, and so on), but Malcolm Messiter “simplified” the whole paradox by just making their own Teensy-powered transmitter and receiver from scratch.
The transmitter uses a Teensy 4.1, and the receiver a 4.0, both equipped with a Nordic nRF24L01+ 2.4GHz transceiver, providing a range of approximately 2.5km! The current firmware supports 16 channels, 12-bit servo resolution, four flight modes, 32 mixes, 99 model memories with import and export, FHSS (Frequency Hopping Spread Spectrum), PWN and SBUS output, failsafe on any channel, digital trims and graphic curves on all channels, and user-defined channel names. All of this is managed via a GUI on a Nextion color touch screen. Binding is via a 64-bit ID for maximum security. These features dramatically exceed the specs of many high-end radio systems costing hundreds, or even thousands of dollars, and are demonstrated effortlessly controlling an SAB Urukay in the video below.
Video Control Surface
YouTuber Zack Freedman wanted to improve his video-editing workflow without spending $100s on new hardware, so he grabbed a Teensy and committed to a one-weekend time limit over which to build his own control surface.
Essentially three normal and one giant knob plus a weird mechanical keyboard, the project is mostly 3d-printed beyond these components, supporting passives, and basic hardware. Source code, design files, and BOM can be found on GitHub, while the accompanying video not only shows you how to put it all together, but also provides a slew of great tips for successful rapid prototyping.
Knife Throwing Machine
Quint BUILDs is known for impressive, entertaining YouTube videos. Having previously relied on Arduino boards for microcontroller projects, his Knife Throwing Machine presented a new challenge due to the real-time calculations required to launch a knife at exactly the right trajectory for it to nail its target tip-first.
This is where the Teensy 4.1 came to the rescue, in order to provide the 18,000 steps per second required by the motors in use. See the resulting insanity in action in the video below, and then go behind the scenes in the video below that.
Breadboard Drum Machine
Sebastian Tomczak, aka little-scale, has built a homemade drum machine around the Teensy 3.6, entirely on a solderless breadboard!
Sixteen button/LED pairs for step sequencing, two 74HC595 shift registers, five further buttons/LEDs for drum/pattern selection and pattern length, and a potentiometer for tempo control are all intricately wired to a pair of large breadboards.
The four channels provide kick, snare, noise-generated hi-hat, and percussive synth samples. Each voice has sixteen steps and four patterns. Each sample channel has 16 samples to select from, and a low-pass resonant filter tailors the overall output. Nanoloop, Pocket Operator, and Sync 24 (DIN sync) help it play nice with other gear. Learn more on the little-scale blog, and check it out in action in the video below!
Tektronix DPO USB Interface
1973’s Tektronix Digital Processing Oscilloscope (or “DPO” for short) was comprised of a 7704A ‘scope and a P7001 digitizer, processor, and memory unit. The processing unit could in turn be connected to an external computer, such as the PDP–11 16-bit minicomputer from Digital Equipment Corporation.
This would have been a dream setup in the 1970s, but in the modern era, the chances of finding a working PDP-11 hanging around to plug your old ‘scope into are rather rare. Which is why Holger Lübben designed the Teensy 4.1-based USB+ Interface, to replace the slow GPIB interface (which was limited to about 50 data words per second) and allow direct connection to a modern PC over USB.
The USB+ Interface is connected directly to the internal bus of the P7001 unit, allowing interaction with every aspect of the instrument, including other plug-in cards. Level shifters facilitate interaction with the 5V system. The software-controlled X/Y mode of the P7001 allows arbitrary vectors to be drawn on the ‘scope, which Holger used to create an on-screen menu to help navigate custom software, such as demos, calibration tools, and even a joke of the day. Extensive detail about the project including pictures, documentation and further resources can be found on the project’s web page.
Original Xbox Controller to USB
There may not be many fans of the original Xbox controller (aka “The Duke”), but Tom Mason, aka wheybags on GitHub, is a big enough fan to take on the task of dragging the infamous behemoth into another generation of gaming with this USB adapter.
Based on the Teensy 4.1, the adapter simply connects an Xbox extension cable to the Teensy’s USB host pins, and then plugs into a PC via USB. By patching the Teensy 3.x ArduinoXInput_Teensy library to work on 4.x, Tom then brought the necessary XInput USB mode to the device, allowing it to appear as a normal Xbox 360 controller to the PC. Tom has a nice blog post detailing the trials and tribulations involved, and the firmware and FreeCAD file can be found in the project’s GitHub repo.
Neutrik etherCON Adapter for Teensy 4.1
Tom Magnier created this alternate Ethernet adaptor using using Neutrik etherCON adapter.
While the standard Teensy 4.1 board provides Ethernet via Ti’s DP83825I PHY, we didn’t want to increase the footprint and BOM with a big ol’ RJ45 MagJack, which is why we sell a separate Ethernet kit for users who wish to incorporate networking into their projects. But there are certainly other ways to implement it, which is why we were excited when we discovered Tom’s design.
The Neutrik etherCON Ethernet connector is widely used in the pro A/V world, and uses standard Ethernet cables, but provides a more rugged, panel-mountable solution. Design files, BOM, and a nice assembly guide can be found on GitHub, with the PCB conveniently available for order on Oshpark.
OpenGalvo
DanielO initially posted with a request for help generating a 10MHz clock signal. What emerged 25 posts later was the release of OpenGalvo, the self-described “minimalistic firmware for processing GCode commands (into the) XY2-100 protocol.”
The reason for doing this? Turning a mirror-based digital galvo into a (potentially unsafe, highly experimental) laser engraver.
DanielO is emphatic about the fact that this is alpha, non-production software that may damage your galvo/laser/Teensy/eyeballs or all of the above, so please keep that in mind should you choose to repro this project. But if you have an XY2-100 galvo, a laser, and a solid-state relay to control it, check out the code on GitHub, and please, please, please be careful and wear eye protection!
Generative Sequencer
Nick Monk (Snowsh) created a monster PCB known simply as “The Machine.” The Teensy 4.1-based behemoth is a generative synth with additional capabilities via expansion modules.
A combination of WS2812 RGB LEDs and OLED displays form the UI, with copious potentiometers and buttons providing the interface. While not much more detail is known about the impressive device, the below video and associated playlist give an idea of its capabilities.
Zoom Phone
Interaction designer Dice Yukita to explore new — or rather old — paradigms for drudgingly routinized daily work from home meetings with his Zoom Phone.
By hacking a commodity USB headset into a traditional telephone handset, plus incorporating the HID capabilities of the Teensy 4.0 and some Swiftbar scripting, Dice was able to realize the classic interactions of telephone usage, like picking up the phone, covering the mic, and having to sandwich the phone between your neck and shoulder in order to accommodate other tasks.
The project builds on his earlier Teensy-based Bidirectional Physical Zoom Mute Button, with the curious “bonus” that upon muting yourself by replacing the handset on the phone’s base, you are also unable to hear other meeting participants, as demonstrated in this video demo.
